Exterior:
• Pintura Lamborghini Diablo Orange
• Do-Luck rear spoiler
• Do-Luck front nose / spoiler
• Veilside side skirts
• Veilside wheel arches
• TRD Bonnet
• 18” Rays Volk TE37 in metallic Black
• BoostLogic 4” straight through exhaust
• HID Lighting
• KAD 356mm 6 pot front brake kit and rear 6 pots
Interior:
• Recaro seats covered with orange Alcantara centres, white leather sides and black leather piping with Supra logo stitched into the headrests.
• Door cards and door handles in white leather with orange Alcantara.
• Dash fascia covered in white leather.
• Defi BF series gauges (Oil pressure, fuel pressure, boost pressure and EGT)
• Isotta Kattianna steering wheel
• AEM AFR gauge
• RaceLogic Traction Control
• Tein EDFC suspension controller
• Blitz SBC i-Color boost controller
Audio/Vídeo:
• Pioneer AVIC X1R DVD Sat-nav head unit
• Kenwood KAC PS811D 1600w sub amp
• Kenwood XXV-02A Anniversary Edition 4 ch amplifier
• Kenwood XXV-04S Anniversary Edition (6.5" comps)
• Focal 6.5" 2 way speakers
• Pioneer TS-SW1241D 12 Shallow mount Sub woofer in cusom enclosure
• 1 Farad Power cap
Motor / Caja de cambios / Tren trasero:
• Polished and ported head
• Ferrea 1mm oversize valves
• Ti springs and retainers
• 1.4mm Head gasket
• ARP head bolts
• ARP rod bolts
• JE Pistons and rings
• BoostLogic single turbo conversion with a T71GTQ turbo
• Boost Logic Ceramic Heat Coated SUS321 Tig Welded Tubular Header
• HKS 50mm SS Wastegate
• Greddy intake manifold
• Q45 Throttle body
• 4” Stainless Steel 304 Downpipe
• 4” Stainless Steel 304 Midpipe
• 4” Aluminum Intake Pipe with Anti-Heat Coating
• 2 1/2" Aluminum Intercooler Pipe with Anti-Heat Coating
• Braided Oil feed and Return Kit with Aeroquip fittings and Lines
• 4" K&N Filter
• HKS 256 inlet and 264 exhaust cams
• Aeromotive fuel pressure regulator
• 720cc Siemens injectors
• Power House Racing Dual feed Fuel rail
• Boostlogic Uprated Auto GearBox
• 3800 Hi stall Torque converter
• Blitz LM FMIC
• LSD
• Boostlogic crank pulley
• Unorthodox racing cam gears and pulleys ( power steering, alternator, & water pump)
• AAP Motorsports Dual Fan Kit with Shroud
• Fluidyne Aluminum Radiator
• Fluidyne Auto cooler w/spal fan
• Powerhouse Racing Alternator
• Hose Techniques hose kit
• Powerhouse racing plug cover
• IPT Motorsports Carbon Fiber Fuse Cover
• MVP Carbon Fiber Radiator Cooling Plate
Sistema electrónico de administración:
Motec M600
Suspensión:• Tein Flex suspension with EDFC
• Carbing Front aluminium Strut Brace with brake stopper
• Whiteline Anti Roll bars
